Odrapnew
Lean Closed Throttle Decel
Post by Odrapnew » Tue Jun 16, 2026 12:28 pm
A9S under GUFB (or is it A).
It's not the same strategy as A9L.
I feel like this question has been asked more than once, but I cannot find good threads (maybe my search skills are degrading).
Anyway, under most conditions, my car runs good.
Fueling seems to be pretty good, except closed throttle deceleration.
I have DFSO active above about 2200rpm.
Under that, closed throttle decel, engine runs lean (~20AFR) and I get lean backfires out the exhaust.
I'm not a teenager with a Honda, so I want to get rid of the lean backfire.
I changed the battery offset values (from values on datasheet) which helped, but that caused it to run rich in almost all other conditions.
If I update the MAF, it seems to go back to extra lean on decel.
I've played with closed throttle OL and commanding rich, but AFR does not match LAMBSE.
If I have closed throttle CL, LAMBSE goes rich to bring to stoich, but then when I get back into the throttle it goes way rich.
What are some tips to help with the lean decel?
'89 Notch, 304(5.0), Novi2K@13psi (currently not installed) TFS heads, TFS Stage 1 cam, Cobra intake, 60lb'ers and 4" MAF with Ford slot sensor, longtubes_x-pipe_flowmasters and more crap that doesnt increase power. 437rwhp@5500(and still climbing)/438rwtq@~4000rpm Tweecer R/T w_BE and EA
Re: Lean Closed Throttle Decel
Post by cgrey8 » Sun Jun 28, 2026 7:46 am
A9P is GUF1
A9S is GUFA
A9L is GUFB
Users browsing this forum: No registered users and 62 guests
