Ryan Bailey
Anyone logging boost correctly with a DataQ?
I have all the stuff to hook this up (except the map sensor).
Just wondering if anyone has had success at logging it correctly with DataQ before I buy the sensor.
Black 94 cobra #2615
Incon 800 TT, J4J1, tweecer R/T, AFR 185, Holley Systemax, F-303, 42# inj, Pro-M Univer
http://www.cardomain.com/ride/536703 Updated 4-27-05
Ryan Bailey
Does anyone know where I can get a plug-in connector to plug into the GM map sensor?
List of GM vehicles to cut it off of or a place/part number to buy it?
- incon_331_twinturbos
1979 Ford Fairmont 4DR.
Moates QH, LC-1, BE/EA
here's some more http://www.dune-buggy.com/turbo/partslist.htm
again
http://forums.evolutionm.net/showthread.php?t=99050
don't know how much good that last on is...it's from an "EVO" board ;)
this one appears to be good as well, it gives harness options too...
http://rdmelton.autoeducation.com/cars/ ... stlog.html
Dale McPeters
Ryan, this is where I got mine from. They also have the pigtail.
http://www.gmpartsdirect.com/results.cfm
Joshua has the transfer curve for it if you need to edit it
www.shonutperformance.com
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
ya, or Dale could chime in and you could get JUST what you need....lol ;)
Brad
Brad
Dale McPeters
incon_331_twinturbos wrote:ya, or Dale could chime in and you could get JUST what you need....lol ;)
Brad
the other info below.....
GM PART # 16040749 *
CATEGORY: Computer Control Sensors
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $0.00
OUR PRICE: $0.00
DESCRIPTION: NO STOCK LEFT ON 16040749 ORDER NEW PART #12223861
This is the first design map sensor for 1989 turbo t/a's.
This part number has changed to the 2nd design and will require using a new connector 15305891 when replacing the first design sensor with the new 2nd design map sensor
If you are installing this on a vehicle other than a 1989 turbo T/A there will not be a warranty on this part.
This is an electrical part which is not returnable per our site policies.
This old part number will be sent until stock is exhausted. Once stock is exhausted the new part number 12223861 will be sent in its place.
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
I just walked into Townsend's Racing Works in Tucson, AZ and picked up their MSD MAP sensor. It was $50 and guess what... it's actually the new style GM sensor, part number and all.
Ryan Bailey
Does anyone know if a naturally aspirated (1 bar) map sensor PIG TAIL is the same as a 2 bar or 3 bar pig tail?
Again I'm wondering just about the pig tail plug in. If it is the same I'm going junk yard hunting.
There is no way I'm paying $20.00 for just a pig tail.
Users browsing this forum: No registered users and 237 guests
